Installing MacBook Unibody Model A1278 Dual Hard Drive
Выберете то, что вам нужно
  1. Installing MacBook Unibody Model A1278 Dual Hard Drive, Access Door: шаг 1, изображение 1 из 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 2, изображение 1 из 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. Installing MacBook Unibody Model A1278 Dual Hard Drive, Battery: шаг 3, изображение 1 из 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. Installing MacBook Unibody Model A1278 Dual Hard Drive, Lower Case: шаг 4, изображение 1 из 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 5, изображение 1 из 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. Installing MacBook Unibody Model A1278 Dual Hard Drive, Optical Drive: шаг 6, изображение 1 из 1
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
    • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
    • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
  7. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 7, изображение 1 из 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  8. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 8, изображение 1 из 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  9. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 9, изображение 1 из 1
    • Remove the two Phillips screws securing the subwoofer to the upper case.
    • The longer of the two screws is on the right.
  10. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 10, изображение 1 из 1
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  11. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 11, изображение 1 из 1
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
  12. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 12, изображение 1 из 1
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  13. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 13, изображение 1 из 1
    • Lift the optical drive from its right edge and pull it out of the computer.
    • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
  14. Installing MacBook Unibody Model A1278 Dual Hard Drive, Optical Drive: шаг 14, изображение 1 из 1
    • Remove the optical drive cable by pulling it straight away from the optical drive.
    • This connector is particularly deep, so be sure to pull away from the drive at the center of the connector.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  15. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 15, изображение 1 из 1
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
  16. Installing MacBook Unibody Model A1278 Dual Hard Drive, Dual Hard Drive: шаг 16, изображение 1 из 2 Installing MacBook Unibody Model A1278 Dual Hard Drive, Dual Hard Drive: шаг 16, изображение 2 из 2
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
  17. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 17, изображение 1 из 3 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 17, изображение 2 из 3 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 17, изображение 3 из 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  18. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 18, изображение 1 из 2 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 18, изображение 2 из 2
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
  19. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 19, изображение 1 из 2 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 19, изображение 2 из 2
    • Use two Phillips #1 screws to secure the drive to its enclosure.
  20. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 20, изображение 1 из 1
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
  21. Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 21, изображение 1 из 3 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 21, изображение 2 из 3 Installing MacBook Unibody Model A1278 Dual Hard Drive: шаг 21, изображение 3 из 3
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
Заключение
82 человек успешно провели ремонт по этому руководству.
Jake Devincenzi
Участник с: 04/18/11
118 139 Репутация
Автор 57 руководств
4 Комментариев
Great guide, thank you! Took me 40 minutes to complete. I also cleaned my cooler fan though as i regularly do. I have moderate experience, Took apart my macbook (and other stuff too) several times. Not doing this daily though. Everyone can do this when keeping the basic rules in mind: Take your time and space and use quality tools.
Albert Zweistein - Ответить
How do you clean the cooler fan? Anyways, do you need to re-apply thermal paste for the Intel chips to keep it cool?
Shyaam D - Ответить
Thank You so much for all the videos. Use I Fm
Ifixit
Philip -
I've follow this guide and everything its ok, except that i cannot mount the drive. The SSD its unnaccesible from this mac
Javier Sánchez León - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 13
За последние 30 дней: 46
За всё время: 74,050
