Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
1. Vehicle Preparation
Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
Remove rear seats as in WIS instructions (Save seat mounting hardware)
Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
Pay attention to the pin to align properly
NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
2. Installation of Front Box
Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
3. Installation of the rear plate
Install 6 rear support brackets and tighten finger tight
Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
Install 3 bolts securing base plate to vehicle frame
and 4th bolt securing the tool box rail to the base plate and vehicle frame.
Put bolt sizes in
Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
4. Install box
Remove drawers and slide box on rail guides, align with bolt holes
Install 6 (M12) bolts and fully tighten to 66 Nm
4 участников успешно повторили данное руководство.
