Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use your finger to open the bobbin door below the presser foot.
Align the hole in the bobbin spindle over the peg in the bobbin case.
Slide the bobbin into the bobbin case, leaving a bit of thread outside the case.
Take the loose thread end and slide it through the slit on the side of the bobbin case.
Slide the thread from the slit straight up along the groove and into the open hole on the bobbin case's side.
Keeping the bobbin in place, turn the bobbin case so that the back is facing you.
Use your fingernail to lift the lever on the back of the bobbin case. Hold the lever open.
Holding the bobbin case lever open, insert the bobbin case into the cavity under the presser foot.
Align the metal arm on the bobbin case so that it sits in the slot in the machine.
Release the bobbin case.
5 участников успешно повторили данное руководство.
