Введение
There are many benefits to adding a second drive to your iMac such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay drive enclosure.
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - Ответить
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - Ответить
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - Ответить
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - Ответить
    Nails worked for me too
    Rob Dale - Ответить
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - Ответить
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - Ответить
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - Ответить
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - Ответить
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - Ответить
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - Ответить
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - Ответить
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - Ответить
  1. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 2, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 2, image 2 of 2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
    What's the best product to clean the face of the LCD?
    Steve Speirs - Ответить
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - Ответить
  2. Installing iMac Intel 21.5" EMC 2308 Dual Drive, Display: step 3, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive, Display: step 3, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive, Display: step 3, image 3 of 3
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
    On reassembly, it is REALLY HARD to align those screws, because of the field of the strong magnets that hold the glass cover on. I'm sure there's a trick to it, but I'd love to know what it is for future reference.
    Peter Shenkin - Ответить
    I used needlenose pliers and the T10 to align the screw into the hole. Otherwise the screw keeps jumping to the magnet. And patience with this NON-CAPTIVE screw design (c’mon Apple, even **I** came up with that, and I’m an idiot!)
    finnik2d - Ответить
    A short piece of small gauge vinyl tubing that fits tightly over the head of the T-10 driver leaving an 8th of an inch or so in which to insert the screw to engage the head will hold the screw long enough to keep it away from the magnet and get it going in the hole.
    Paul Boudreau - Ответить
    I use non magnetic SS curved tip tweezers together with a magnetized #10 torx bit both to remove and reinstall the screws. You can magnetize and demagnetize the bit using the strong magnets on the LCD frame. Don't worry too much during removal, you can recover the screw. But loath the moment you drop the last screw during reassembly. For that reason, reinstall the screws near the magnets and hardest to get to first.
    Michael Ben-Yehuda - Ответить
  3. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 4, image 1 of 1
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
    When putting the display back I have resistance from the foam elements (on the top end where the iSight is) and have to press down really hard. Is that okay?
    gm.konsortium - Ответить
    Well, stupid me put the 3.5" to 2.5" cage the wrong side up. ;)
    Standing the imac upright on its stand really helps this step! Laying it falt makes getting under the panel a real hassle.
    finnik2d - Ответить
  4. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 5, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 5, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 5, image 3 of 3
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
    The vertical sync cable was snug initially and now is loose. I checked and the cable is intact. Has anyone had experience with making it fit better?
    Rajan - Ответить
    Scotch tape on the upper side and sliding this in helped to secure the cable.
    Rajan - Ответить
    Reassembly of this part was the closest I came to disaster on this project. I tried inserting the connector a few times without success, and when I looked it it the leads, which are fragile, were all mangled. I smoothed them out by hand as best I could and and reinserted, very carefully this time. The trick is that the tip of the connector should be pointed somewhat upwards when reconnecting.
    I was pretty sure that when I was done, I would reboot but have no display; but fortunately, everything worked.
    Hi, I still have a question. What is the "Job" of the vertical sync ribbon cable. Thanks
    Lutz Blum - Ответить
    So let’s say someone wanted to suck some of the dust off the back of the display before reassembly. Let’s just say that. Someone would likely suck this forsaken cable up into the vacuum tube then, wouldn’t they? They might. And if it were to oscillate in a rushing torrent of air, it might get munged? It might.
    Here’s how you overcome such a disaster:
    1) cut the end fresh, as close to the end as you can while cutting off any frayed end.
    2) abrade the end gently, repeatedly, along the connector wire axis. I used emory paper. Your goal is to expose the copper conductors in the last 1/4” of the fragile evil wire.
    3) Tape a small stiff cardstock to the back of the end of the connector. This is essential to press the connector wires into the connector.
    4) Gently insert, taking special caution to not peel the copper off of the connector.
    5) Tape that connector down deftly, without letting it move a millimeter and securing it for all time.
    sydnius - Ответить
    I just leave it connected. After disconnecting the other cables, there is enough slack to lay the display on its backside if you’re working on a flat surface.
    Duane Johnson - Ответить
    I have replaced the hdd in this model about 8-10 times - I have never had to disconnect any cables other than the sata and temp sensor cables on the hdd. I just prop the lcd up with an egg carton (or something about 3 inches high that is soft and light) and access the hdd that way. The only thing I ever have trouble with are is putting the LCD screws back in around the magnets - but I have pretty much perfected that with a sissor/ tweezer tool.
    Suzanne Levy - Ответить
    Could you put up some photos of this procedure - egg carton etc…
    Peter Barnett -
    Any ideas where to replace this cable?
    Danny Shaw - Ответить
    I followed Suzanne’s comment and also did not disconnect this cable (vertical sync ribbon cable) to avoid damage. I pivoted the screen about 110 degrees after the other cables where detached. On a flat surface, this is easily done and the cable is not tight. Image of my angle if I can drop a link. and cable in this position not in tension.
    investments kkl - Ответить
    Where can I buy the replacement for this vertical sync replacement cable?
    Neil Gonsalves - Ответить
  5. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 6, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 6, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 6, image 3 of 3
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
    I found it easier to very slightly lift the front edge of the black connector with a small spudger, then gently pulling away towards the bottom of the iMac. Pressing felt a little crude and didn’t work for me.
    Anthony C Carnell - Ответить
  6. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 7, image 1 of 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
    in Step 7, my connector (new 21.5 iMac - Dec 2010) was not attached that way and just came of easily.
    erin - Ответить
    Aperte as duas exibição do conector do cabo de dados braços juntos para desbloqueá-lo de seu soquete na placa lógica.
    Darlan Perira da Silva - Ответить
    I accidently broke the data cable socket on step 7. Any advice on what i should do?
    Sam Tang - Ответить
    I feel pretty silly. I spent wayyyy too long trying to get these cables disconnected. Happy I found this guide; hopefully, I won't struggle with such simple things since you provide pretty good details! Thanks.
    J.w. - Ответить
    Pas beaucoup de place pour déconnecter ce cable ! En essayant d'ouvrir trop l'écran pour passer mes "grosses mains" j'ai cossé le connecteur : je suis dans le caca :-( (et pourtant j'en fait des démontages !) Alors ATTENTION !!!
    divers - Ответить
    Il vaut mieux déconnecter la partie du côté écran en premier (sous l'autocollant noir)
    divers - Ответить
    Je suis d’accord. C’est plus facile. Merci mon ami
    Anthony C Carnell -
    Translation: It is better to disconnect the screen side first (under the black sticker)
    Michael Seiler -
  7. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 8, image 1 of 1
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
    This is important regarding the fan running full speed
    http://blog.macsales.com/19617-diagnosin...
    tobykirkland - Ответить
    Is there a way to test the power supply to see if it's dead?
    professorminh - Ответить
    Achtung! Dieser Stecker kann sehr fest sitzen, hier hilft ein guter Fingernagel um den Stecker abwechselnd rechts und links zu Hebeln
    bluesoundsmusic - Ответить
    English translation of bluesoundsmusic comment: “Caution! This plug can be very tight, here a good fingernail helps to lever the plug alternately right and left”
    investments kkl -
  8. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 9, image 1 of 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  9. Installing iMac Intel 21.5" EMC 2308 Dual Drive, Optical Drive: step 10, image 1 of 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    While you’re here, disconnect that SD reader cable and don’t forget to plug it back in on your way back through: it’s not mentioned elsewhere in this guide.
    Corvallis Computer - Ответить
    For me this cable was by the hard drive with a grey and a black wire labeled “ODD_TEMP”
    Bryan Remely - Ответить
  10. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 11, image 1 of 1
    • Remove the four 9 mm T10 Torx screws securing the optical drive to the outer case.
  11. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 12, image 1 of 1
    • Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
  12. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 13, image 1 of 1
    • Use the flat end of a spudger to help disconnect the optical drive cable.
    Be sure this cable doesn’t get stuck under the logic board during reassembly. Mine was under it, I was able to get it out but connecting it to the SuperDrive required a bit of force because my cable is so short.
    Javier Indesteege - Ответить
  13. Installing iMac Intel 21.5" EMC 2308 Dual Drive, Optical Drive: step 14, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive, Optical Drive: step 14, image 2 of 2
    • It is not necessary to peel all of the EMI tape off the optical drive bracket. Only peel up the portion highlighted in red that is attached to the body of the optical drive.
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
  14. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 15, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 15, image 2 of 2
    • Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
  15. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 16, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 16, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 16, image 3 of 3
    • If necessary, use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
  16. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 17, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 17, image 2 of 2
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
    Can you (re)use this exact thermal sensor on the optical drive and attach it to a new SSD?
    Ali Mir - Ответить
    @AliMir - yes, you can reattach the thermal sensor to the new SSD
    osienna - Ответить
    Hello, I've broken the temperature sensor of the unit superdirve, where I can buy one?
    Angel Blasco - Ответить
  17. Installing iMac Intel 21.5" EMC 2308 Dual Drive, Optical Drive Enclosure Faceplate: step 18, image 1 of 1
    • Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
    Hello, is the sata & power cabla from the mac can directly feet inside the SSD?
    Roman Quenin - Ответить
    plug in the back of the ssd
    Roman Quenin -
    I'm trying to find out as well. I read elsewhere you need something like this without the bracket: http://www.amazon.com/gp/product/B0056OB...
    However I have NOT confirmed this.
    Allen Borza -
    If I understand you correctly; the enclosure allows you to use the existing iMac optical cable. Also the enclosure allows for a safe fitting of the optical drive. In my newer machine I had to double side tape the SSD to the back of the iMac and buy a special cable. Note: this was not an optical drive replacement scenario or I would have done exactly as this tutorial suggests.
    EkDor - Ответить
    I bought another caddy, not the one from the description. i had to extract the plastic adaptor from the optical drive and put in on the new caddy 12,7mm
    Cristian Pizarro - Ответить
    The SDD caddy I purchased was 22 pin SATA both inside and outside so that the optical drive cable (13 pin) would not fit. Does anyone know where I can find a SDD caddy with 13 pin SATA outside for the optical cable and 22 pin SATA inside for the SDD?
    benja.mcg - Ответить
  18. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 19, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 19, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 19, image 3 of 3
    • Starting from the left edge, gently pull open the optical bay enclosure.
    • Continue to pull open the two halves of the enclosure until they separate.
    This is the 12.7mm caddy.. but, the caddy 9.5 mm fit fine as well? or it doesn't fit on imac mid 2010
    My caddy (ordered 5/2019) had two additional screws that needed to be removed from the sides for it to open.
    mr.kaufman7 - Ответить
  19. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 20, image 1 of 1
    • Remove the two 3.0 mm Phillips screws securing the faceplate to the optical bay enclosure.
  20. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 21, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 21, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 21, image 3 of 3
    • Lift the black plastic faceplate out of the optical bay enclosure.
    • You will no longer need the faceplate or the two Phillips screws that held it in place. Set those parts aside if you ever wish to put the faceplate back into the enclosure.
    • Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
    Just curious, why is it necessary to remove this black plastic faceplate from the enclosure? It doesn't appear to serve any function in or out of the enclosure.
    Nic Johnson - Ответить
    Maybe because it would interfere with the bracket you have to put back on in step 21?
    Jeff Dickson -
    So I'm confused about the Optical Drive Bracket, the one that originally held the DVD-CD drive. I had an awful time remounting the kit into that bracket as the screws didn't line up correctly. I finally got everything to fit, less one of the four holding screws. Did anyone else experience this problem? I would have expected a much better alignment for this assembly considering the quality of the iFixIt site.
    For the record, the upgrade went fine with a SanDisk Extreme II 480GB SSD, but that one step was next to impossible, and not covered in any detail by the instructions.
    Ron Lockhart - Ответить
    Yep, I had exactly the same problem. The alignment was way off.
    olafgoy -
    My kit also did not line up correctly. I had to put all four screws in at an angle cross-threaded to mount the unit.
    Kevo -
    Same here. managed to get two screws in at a decent angle on one side and couldn't get the others in. Felt solid enough once I'd screwed the original ODD casing back onto the iMac.
    Monkeyrebirth -
    I had the same alignment problem, too. I ended up removing the rubber grommets from the plastic enclosure, widening the holes with a small file, then replacing the grommets. All four screws went in, but not in perfect alignment. Should be ok, though.
    nickmalmquist -
    Another possibility is the part has been designed to be used with different types of iMac and some utilise this component. In this case it apparently doesn't.
    EkDor - Ответить
    I bought a different enclosure than the one recommended ($18 instead of $39) and it came with new screws because the old screws were too big to fit in the holes for the new enclosure.
    Keith Mewis - Ответить
    Hi. Which enclosure did you buy? link please.
    Alex -
    Where did you get the alternative enclosure from?
    Walter Poole -
    I completed this guide last night on my iMac and it all worked great until I got to step 26 and none of the holes on the 12.7 mm PATA Optical Bay SATA Hard Drive Enclosure lined up with the black plastic faceplate. Just like what is being commented on by previous fixers, I could only get 2 screws on one side of the enclosure in, but they were crooked and unable to screw in all the way. It was crude, but it worked.
    The rest of this guide works flawlessly. This is a great site!
    Marc - Ответить
  21. Installing iMac Intel 21.5" EMC 2308 Dual Drive, Dual Hard Drive: step 22, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive, Dual Hard Drive: step 22, image 2 of 2
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    What’s the switch for on the inside of the caddy? What position should it be in? Mine came switched to the right (towards SATA connector that disk inserts into).
    Robert Lord - Ответить
  22. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 23, image 1 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 23, image 2 of 3 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 23, image 3 of 3
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  23. Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 24, image 1 of 2 Installing iMac Intel 21.5" EMC 2308 Dual Drive: step 24, image 2 of 2
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    Why no mention of attaching the new hard drive to the Optical Drive Enclosure using the enclosed phillips screws?
    Once you have securely inserted the new hard drive into the Optical Drive Enclosure and replaced the plastic positioner you should attach the drive to the enclosure using two of the provided phillips screws. Two holes on the underside of the enclosure should align with two attachment holes on the underside of the drive.
    nickmalmquist - Ответить
    I suspect that the plastic positioner will secure the drive well enough (for this style of adapter). As I mentioned in earlier comment, this should mean you can replace / upgrade the SATA drive later without needing to remove the adapter, skipping many steps.
    Les Kitchen -
    Do you need a sata cable to connect the new drive to the board or does it connect via the optical drive cable that we disconnected earlier?
    Erik Sawaya - Ответить
    It does connect to the optical drive cable but if you don't use the optical bay enclosure you'll need a 13 pins to 22 pins sata adaptor (and some tape!)
    The sata cable for the optical drive has 6 + 7 pins while ssd and hhd have 15 + 7 pins
    Graziano Nora - Ответить
    Can someone please explain why you need to remove the black plastic faceplate  from the optical bay enclosure. It is designed to receive the standard SSD. What is gained from removing a part of it?
    Peter Bull - Ответить
    Thank you! This guy has made upgrading the mid 2010 iMac I inherited from my mom MUCH easier and saved me a lot of time, trial, and error.
    Rob Anthony Dire - Ответить
    My Penrynn Super Drive has PATA connector, and now is a fossil grade rarity :-(
    IMI Comp - Ответить
Заключение
51 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 05.03.2012
87 492 Репутация
Автор 132 руководств
9 Comments
I followed this guide to place a samsung 840 EVO 750 GB ssd in the optical drive bay. The instructions worked near perfectly. However, I got many SATA CRC errrors. Not a connector seating problem. After placing the SSD in the hard drive bay (following the hard drive replacement guide) no more CRC errors.
I tested with an older laptop hdd: This works fine in the optical bay.
Apparently either the optical drive bay does not work well with the samsung 840 EVO or my optical drive cable is no good.
I reassembled my superdrive and placed the SSD in place of my built-in HDD for a nice speed increase.
Is there any listing of ssds that work well in the OD bay?
Allard Mosk - Ответить
I recently replaced my HD with an SSD drive. Watching this guide actually helped too!
I would also like to replace the optical drive with a Hard Drive. Would it make much of a difference wether I use a SSD or a 7200rpm HD? I would be using it for video and audio files for Protools and Final Cut Pro that are running on the SSD..
It seems like the negotiated speed on the optical SATA is only 1.5 Gigabit..
Ron kauvon - Ответить
Do you attach the thermal sensor to the equivalent place on drive enclosure as it was on the optical drive?
Kevin Quinn - Ответить
Would love to know how to re-use the optical drive externally, with an inexpensive enclosure.
Rob Wilderman - Ответить
There is the OWC SuperSlim (https://eshop.macsales.com/item/Other%20...) The iMac drive looks at least half again as thick as a laptop drive, so there would be a gap between the top and bottom pieces of the SuperSlim - maybe build a thin wood frame to take up the gap? Four pieces, each about a quarter-inch thick, glued or lapped on the corners. If you want to be *really* nifty, maybe try to do a dove-tail on each corner - but that would require cutting about 2 mm "doves and tails".
jimwitte -
Is scotch tape inside the mac likely to dry out or fall apart "quickly"? The bracket I had for the optical drive (the DataDoubler bracket designed for laptops) didn't fit, and I didn't have a proper 2.5->3.5 adapter plate for the main hard drive, so I just ended up "mounting" them using the optical drive EMC tape for one, and a fair amount of scotch tape on both to keep them from completely flopping around in there too much - it is a *desktop* after all. Will this work? And will having both of them at an angle with one edge touching the back of the machine (and the tape) create thermal problems? The SSDs are both Crucial brand, 240GB.
I'll probably be opening the thing up again in the next week - there was an *incredible* amount of dust in the fans - it seemed surprising though I it shouldn't. Can you get "dust suckers" to clean dust from fan blades and such without having to remove the fans themselves? I don't want to brave a full tear-down. Getting 8 metal screws back in past NeoDy magnets was tough!
jimwitte - Ответить
Is scotch tape inside the mac likely to dry out or fall apart "quickly"? The bracket I had for the optical drive (DataDoubler bracket for laptops) didn't fit, and I didn't have a proper 2.5->3.5 adapter plate for the main hard drive, so I just ended up "mounting" them using the drive EMC tape for one, and a fair amount of scotch tape to keep them from completely flopping around in there - it is a *desktop* after all. Will this work? And will both of them being at an angle with an edge touching the back of the machine (and tape) create thermal problems? DVD one still has the temp sensor, the other is shorted. Both are both Crucial brand, 240GB.
I'll probably be opening the thing up again - there was an *incredible* amount of dust in the fans - it seemed surprising though I it shouldn't. Can you get "dust suckers" to clean dust from fan blades and such without having to remove the fans themselves? I don't want to brave a full tear-down. Getting 8 metal screws back in past NeoDy magnets was tough!
jimwitte - Ответить
If I use a SSD drive would I lost some performance by connecting it to the optical drive SATA slot?
Is the SATA slot connecting de 3.5" hard drive more efficient?
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 29
За последние 30 дней: 159
За всё время: 66,076
