Введение
How to replace the float valve on the Instant Pot IP-DUO. This procedure and part is the same for the following models: IP-DUO50, IP-DUO60, and the IP-DUO80.
Выберете то, что вам нужно
Remove the white rubber cover from the red float valve by pulling it off gently.
2 участников успешно повторили данное руководство.
2 Комментариев
On my model, the metal housing broke off, looks like it will need to be welded back together to the lid.
my float valve rubber is missing what can i do???how i can oder this how m gonna fix it kindly answer
