Inter-tel IP 8660 Handset Microphone and Receiver. Replacement
Выберете то, что вам нужно
  1. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Back Cover: шаг 1, изображение 1 из 1
    • Disconnect the phone cord from the handset jack.
  2. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 2, изображение 1 из 2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 2, изображение 2 из 2
    • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
  3. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 3, изображение 1 из 2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 3, изображение 2 из 2
    • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
  4. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement, Handset Microphone and Receiver.: шаг 4, изображение 1 из 1
    • While holding the handset front cover, grasp and twist the handset microphone and jack until they come free from the cover.
  5. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 5, изображение 1 из 3 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 5, изображение 2 из 3 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 5, изображение 3 из 3
    • Unscrew the 2 screws (8 mm long) that hold the receiver in place using a #1 Phillips screwdriver.
    • Note: The screws come with washers.
  6. Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 6, изображение 1 из 2 Inter-tel IP 8660 Handset Microphone and Receiver. Replacement: шаг 6, изображение 2 из 2
    • Pull the red and green wires that connect the receiver to the microphone out from under the metal piece and black padding.
    • Note: To insert the wires back underneath the black padding, pull the black padding back with your finger and use plastic opening tool to wedge the wires underneath the black padding.
Заключение
Juan David GutierrezFranco
Участник с: 01/20/12
67 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 11-24, Maness Winter 2012 Участник Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 965
