Введение
This guide details the steps to take off the rear cover of your Inter-tel IP 8660.
Запчасти
Никакие детали не требуются.
  1. Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  4. Lift up the back cover and set it aside.
    • Lift up the back cover and set it aside.
Заключение
Mariano Bautista
Участник с: 20.01.2012
16 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 473
