Введение
Use this guide to replace an Interlink VP4550 Circuit Board.
Запчасти
Никакие детали не требуются.
  1. Turn the phone over to where the battery compartment resides. Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device. Remove battery.
    • Turn the phone over to where the battery compartment resides.
    • Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
    • Remove battery.
  2. Use a Phillips #0 screwdriver  to remove the screw in the middle of the battery compartment. Pry open the case body with the plastic opening tool.  Start at the bottom of the device and work toward the top.  You will hear a "click" sound as the sides open. Pry open the case body with the plastic opening tool.  Start at the bottom of the device and work toward the top.  You will hear a "click" sound as the sides open.
    • Use a Phillips #0 screwdriver to remove the screw in the middle of the battery compartment.
    • Pry open the case body with the plastic opening tool. Start at the bottom of the device and work toward the top. You will hear a "click" sound as the sides open.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. There is a wire connector linking the front and the back of the device. Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
    • There is a wire connector linking the front and the back of the device.
    • Carefully pull the wire connectors out of the white connector gauge to completely separate the front and back pieces.
  5. The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling. Find the lever on the right side of the back half of the device.
    • The power button may fall off when you separate the front and back of the device. This can simply be placed back when reassembling.
    • Find the lever on the right side of the back half of the device.
    • Insert the tip of the lever into the square indent on the underside of the button.
  6. Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Avoid picking up the front of the device as you work so that loose parts will not shift.
    • Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
  7. Slide the circuit board down from the tab located underneath the top of the back half
    • Slide the circuit board down from the tab located underneath the top of the back half
    • The laser is attached to the circuit board and will slide out of its own housing as you slide out the circuit board.
      • Use tweezers to gently remove it if it doesn't come out.
Заключение
custer78
Участник с: 11.02.2014
24 Репутация
1 Guide authored
Команда
Ohio State, Team 1-1, Buehl Spring 2014 Member of Ohio State, Team 1-1, Buehl Spring 2014
OSU-BUEHL-S14S1G1
4 членов
Автор 3 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 176
