Выберете то, что вам нужно
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Grab the cover by the front side and pull upwards.
You might encounter some resistance. Pull firmly, but don't yank it.
Tilt the front case down until the pegs detach from the bottom of the case.
Lift up and outward.
There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
5 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
Great guide exactly what I was looking for.
Zip disks were awesome, and they still are they fit that niche between needing something small in capacity but not large enough for a USB flash drive.
