Введение
this guide is to show you how to open up your irulu walknbook windows 10 tablet.
Выберете то, что вам нужно
first remove the orange (or other colour) bezels from the side of the tab. the all have a small hole grip.
on the back cover there is a glass cover that covers up the screws. be carefull when removing it because it might break. use small like credit cards to seperate it but still be very carefull.
so the back cover seperates in to two parts. after removing the glass part the screws are visible. remove all of them. the back cover can pe removed very easily.
you then end up with all the rest of the internal parts visible. now you can replace the battery or the display. there is also a 3g port slot but i haven't tried it out yet. let me know if this worked for you.
6 участников успешно повторили данное руководство.
11 Комментариев
where can I buy a replacement battery for this walknbook????
Donde puedo comprar la batería ,no la encuentro.
Necesito comprar la batería para la irulu
Battery:7800 mAh irulu w1002
Donde la venden.
