Введение
How to disassemble the JBL Charge 2 for a battery replacement.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
Remove the end cap of the device. Repeat the same process to remove the other end cap.
To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
Twist off the end cap and remove them from the device.
Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
Pry away the plastic battery cover with a plastic spudger.
Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
Slide the battery free.
10 участников успешно повторили данное руководство.
3 Комментариев
Thanks for the manual! Easy repair this way.
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
