Выберете то, что вам нужно
Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
Follow the previous instruction to remove the back grille.
Unscrew the two .5 mm screws that hold the sub woofer in place.
Repeat the last step for the two screws on the back side.
7 участников успешно повторили данное руководство.
3 Комментариев
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
