JBL Charge 3 Battery Replacement
Выберете то, что вам нужно
  1. JBL Charge 3 Battery Replacement, Front Cover: шаг 1, изображение 1 из 3 JBL Charge 3 Battery Replacement, Front Cover: шаг 1, изображение 2 из 3 JBL Charge 3 Battery Replacement, Front Cover: шаг 1, изображение 3 из 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Battery Replacement: шаг 2, изображение 1 из 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Battery Replacement, Passive Radiators: шаг 3, изображение 1 из 3 JBL Charge 3 Battery Replacement, Passive Radiators: шаг 3, изображение 2 из 3 JBL Charge 3 Battery Replacement, Passive Radiators: шаг 3, изображение 3 из 3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  4. JBL Charge 3 Battery Replacement: шаг 4, изображение 1 из 2 JBL Charge 3 Battery Replacement: шаг 4, изображение 2 из 2
    • Insert the plastic opening tools underneath both tabs.
  5. JBL Charge 3 Battery Replacement: шаг 5, изображение 1 из 1
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
  6. JBL Charge 3 Battery Replacement: шаг 6, изображение 1 из 2 JBL Charge 3 Battery Replacement: шаг 6, изображение 2 из 2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
  7. JBL Charge 3 Battery Replacement, Battery: шаг 7, изображение 1 из 3 JBL Charge 3 Battery Replacement, Battery: шаг 7, изображение 2 из 3 JBL Charge 3 Battery Replacement, Battery: шаг 7, изображение 3 из 3
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
  8. JBL Charge 3 Battery Replacement: шаг 8, изображение 1 из 3 JBL Charge 3 Battery Replacement: шаг 8, изображение 2 из 3 JBL Charge 3 Battery Replacement: шаг 8, изображение 3 из 3
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
  9. JBL Charge 3 Battery Replacement: шаг 9, изображение 1 из 2 JBL Charge 3 Battery Replacement: шаг 9, изображение 2 из 2
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
  10. JBL Charge 3 Battery Replacement: шаг 10, изображение 1 из 1
    • Pull the battery and battery cable out from their housing.
Заключение
100 участников успешно повторили данное руководство.
Jack Ng
Участник с: 10/08/18
1 740 Репутация
Автор 4 руководств
Команда
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Участник Cal Poly, Team S1-G6, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G6
4 членов
Автор 26 руководств
26 Комментариев
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - Ответить
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - Ответить
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - Ответить
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 143
За последние 7 дней: 934
За последние 30 дней: 3,758
За всё время: 164,596
