JBL Charge 3 Button Replacement
Выберете то, что вам нужно
  1. JBL Charge 3 Button Replacement, Front Cover: шаг 1, изображение 1 из 3 JBL Charge 3 Button Replacement, Front Cover: шаг 1, изображение 2 из 3 JBL Charge 3 Button Replacement, Front Cover: шаг 1, изображение 3 из 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Ответить
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Ответить
    There are two Phillips head screws to remove before prying the cover off
    jason - Ответить
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Ответить
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Ответить
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Ответить
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Ответить
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Ответить
  2. JBL Charge 3 Button Replacement: шаг 2, изображение 1 из 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - Ответить
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Ответить
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Ответить
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Ответить
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Ответить
  3. JBL Charge 3 Button Replacement, Button: шаг 3, изображение 1 из 2 JBL Charge 3 Button Replacement, Button: шаг 3, изображение 2 из 2
    • Use your plastic opening tool to pry around the edges of the button cover. This will begin to separate the adhesive from the cover.
    • Peel away the button cover with your hand once you have enough separated from the speaker housing to grab.
  4. JBL Charge 3 Button Replacement: шаг 4, изображение 1 из 2 JBL Charge 3 Button Replacement: шаг 4, изображение 2 из 2
    • Flip open the top flap on the ZIF connector.
    • Gently pull out the ZIF connector cable with tweezers.
    What is the purpose of pulling out the ZIF connector cable with tweezers? What do you do after you you've pulled it out?
    Bradford J Stallworth - Ответить
Заключение
13 участников успешно повторили данное руководство.
Sunmin Yoon
Участник с: 10/30/18
1 850 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S13-G1, White Fall 2018 Участник Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 членов
Автор 26 руководств
4 Комментариев
my jbl dont turn on even its in charge it wont turn on
batteries are new but still wont wor
D- ASTRO - Ответить
Where do i buy new buttons?
Thomas Bjerregaard - Ответить
Could you please provide info about where to get the green board?
Alvaro Pérez Morales - Ответить
Next steps are missing.
5.) What happens after the disconnecting the ZIF?
6.) a.) How do you remove the button board? Is that what needs to then be replaced?)
6.) b) Or do I need soldiering skills and learn to attach new buttons to the existing board.
Happy to learn - hoping to be pointed in the right direction...
Mark Freeman - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 89
За последние 30 дней: 431
За всё время: 22,208
