Введение
Going on to further repairs or just replacing a broken front cover? This guide will teach you the first step of opening up your JBL Charge 3.
Инструменты
Запчасти
Детали не указаны.
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Pull apart your cover gently from both sides and remove it from the speaker housing.
4 участников успешно повторили данное руководство.
Один комментарий
where can i buy a new front cover for mine? mine has got cracked
