Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The JBL Charge 3 has two front speaker that can be replaced individually or together. If your speakers are blown out replace them with this guide.
Выберете то, что вам нужно
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Pull apart your cover gently from both sides and remove it from the speaker housing.
Remove the eight 10mm Phillips #1 screws from around the two front speakers.
Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
42 участников успешно повторили данное руководство.
31 Комментариев
I need to replace my JBL charge 3 speaker
Where can buy the small speakers? Helpp
I have to pull out the motherboard to get those speakers out.
where can i buy the replacement speakers?
