Введение
The carabineer on the JBL Clip 2 is removable. If the carabineer mount does not work, you will notice that the device will no longer clip on to secure locations. If this is the case the carabineer mount will have to be replaced. The device will be taken apart and the carabineer mount will be removed and replaced.
Выберете то, что вам нужно
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
There will be six 3 mm T8 screws under the cap, remove these six screws.
If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
3 участников успешно повторили данное руководство.
2 Комментариев
i want to find that part ,dou you have web link to by
