Введение
If your JBL Clip 3 clip mechanism is no longer functioning, or has broken, the carabiner clip may require replacement.
This guide will show you the step by step process of replacing a carabiner clip for a JBL Clip 3. The process won’t be too difficult, requiring no special skills. Make sure to be careful when removing parts, because they can be fragile.
Выберете то, что вам нужно
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
Еще один человек закончил это руководство.
