Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through from taking apart the device, disconnecting all the cables inside and taking apart the battery for replacement.
There are two versions of the battery in this device; one with three wires and one with five wires. The best way to tell which type of battery you need is to disassemble your device before ordering a replacement battery.
Выберете то, что вам нужно
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
Repeat the same process for the 4 remaining metal nibs (two on each end).
Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Wedge a spudger between the two halves where the tape was to pry the device open.
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
Remove the one 7.0 mm Phillips #1 screw attaching the motherboard to the casing.
Lift the motherboard out of the case to reveal the battery.
Remove the cord that connects the ports board to the motherboard.
Put the motherboard to the side.
Using the black spudger, loosen the brace holding in the battery.
To remove the brace, turn it 90 degrees clockwise and lift it up from its socket.
18 участников успешно повторили данное руководство.
10 Комментариев
were i can buy a new battrery?
I just managed to find a replacement battery for the older JBL Flip2 , which has a LI-ion battery (just three cables with a different connector) for in this feature just the newer Lipo battery is covered:
This is the right battery for the early version:
https://www.amazon.de/gp/aw/d/B002XCR3UI...
it has a different connector , so soldering the old connector to the new battery is required: Easy enough, since the colors are the same - yellow to yellow , black-black and red-red.
it‘s a tiny bit wider so with a knife the side holders have to be cut out a little, you will see when you receive the battery.
open it up first and you will see which version you have, the LIPo version has the connector at the front as pictured above, the LI-ion version has a 3pin connector at the backside of the PCB.
fir this version you need a LI-ion battery as in the link above.
Everything else is just as described above - ists such a great little speaker and Im happy that it plays again… ;-)
