JBL Flip 2 MicroUSB Port Replacement
Выберете то, что вам нужно
  1. JBL Flip 2 MicroUSB Port Replacement, JBL Flip 2 Outer Case Disassembly: шаг 1, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement, JBL Flip 2 Outer Case Disassembly: шаг 1, изображение 2 из 2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
    From where i can buy these speakers?
    Nitin Z - Ответить
    First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
    Ken McMahon - Ответить
  2. JBL Flip 2 MicroUSB Port Replacement: шаг 2, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 2, изображение 2 из 2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
  3. JBL Flip 2 MicroUSB Port Replacement: шаг 3, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 3, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 3, изображение 3 из 3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
    what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
    dfhdrt34f3t - Ответить
    Need the real name of the NFC chip, caus i broked and need to change
    Thanks
    Daniel Huot - Ответить
    Need the real name of the NFC chip, cause i broked and need to change
    Thanks
    My chip reads WN-3088 20130912
    Thomas Blanchard - Ответить
  4. JBL Flip 2 MicroUSB Port Replacement: шаг 4, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 4, изображение 2 из 2
    • Peel the black rubber piece from one end to the other.
  5. JBL Flip 2 MicroUSB Port Replacement: шаг 5, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 5, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 5, изображение 3 из 3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
    Tutto molto interessante.
    Ma la cosa più importante è:
    Dove acquistare gli altoparlanti ??
    terlizzigianfranco75 - Ответить
  6. JBL Flip 2 MicroUSB Port Replacement: шаг 6, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 6, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 6, изображение 3 из 3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
  7. JBL Flip 2 MicroUSB Port Replacement: шаг 7, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 7, изображение 2 из 2
    • Expand the metal casing and carefully slide it off the speaker.
  8. JBL Flip 2 MicroUSB Port Replacement: шаг 8, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 8, изображение 2 из 2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
  9. JBL Flip 2 MicroUSB Port Replacement: шаг 9, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 9, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 9, изображение 3 из 3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
    For easier removal warm the tape up with a hair dryer. It tears apart very easily.
    hale1730 - Ответить
    Keeping the tape intact is impossible - I replaced it with electrical tape.
  10. JBL Flip 2 MicroUSB Port Replacement: шаг 10, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 10, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 10, изображение 3 из 3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  11. JBL Flip 2 MicroUSB Port Replacement: шаг 11, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 11, изображение 2 из 2
    • Use the black spudger to disconnect the speaker cord from it's socket.
  12. JBL Flip 2 MicroUSB Port Replacement: шаг 12, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 12, изображение 2 из 2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
    What is the function of auxi. Wire
    Debabrata Paul - Ответить
    When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
    Jose Palacios - Ответить
  13. JBL Flip 2 MicroUSB Port Replacement: шаг 13, изображение 1 из 1
    • Carefully remove the cable connecting the control chip to the motherboard.
    What's the name of the cable connecting the control chip to the motherboard
    Jose Cabello - Ответить
    I want motherboard control chip
    moneykandan110 - Ответить
    connecting the control chip kitne ka hai
    Niraj Kumar - Ответить
  14. JBL Flip 2 MicroUSB Port Replacement: шаг 14, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 14, изображение 2 из 2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
    If you can“t see a connector here , you have an earlier version of Flip2 - the connector is on the backside and requires a different battery - see the comment at the end of the feature
    Klaus - Ответить
  15. JBL Flip 2 MicroUSB Port Replacement: шаг 15, изображение 1 из 1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
  16. JBL Flip 2 MicroUSB Port Replacement, MicroUSB Port: шаг 16, изображение 1 из 1
    • Remove the 7.0 mm Philips #1 screw that connects the I/O board to the casing.
  17. JBL Flip 2 MicroUSB Port Replacement: шаг 17, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 17, изображение 2 из 2
    • Remove the white ribbon cable that connects the I/O board to the motherboard.
    • Put the motherboard to the side.
  18. JBL Flip 2 MicroUSB Port Replacement: шаг 18, изображение 1 из 2 JBL Flip 2 MicroUSB Port Replacement: шаг 18, изображение 2 из 2
    • With the black spudger, carefully wedge out the I/O board.
    • Be careful not to damage the I/O board with the black spudger.
  19. JBL Flip 2 MicroUSB Port Replacement: шаг 19, изображение 1 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 19, изображение 2 из 3 JBL Flip 2 MicroUSB Port Replacement: шаг 19, изображение 3 из 3
    • Gently pull the I/O board out from the speaker.
    Where can I get the micro USB port
    Jose - Ответить
    Mine does not look like this. The charg port board is smaller & by itself
    Kimberly Weakley - Ответить
  20. JBL Flip 2 MicroUSB Port Replacement: шаг 20, изображение 1 из 1
    • Check out IFixit's official soldering guide for help with these special projects.
    • Pry off the loose MicroUSB port.
    • Use the soldering iron to solder the new MicroUSB port onto the I/O board.
    • Soldering iron will be very hot.
    Don't pry anything off! Desolder the bad port!
    If you pry, you most likely will lift the copper traces and ruin the very traces you will need to solder to.
    Patrik Floding - Ответить
    Link to replacement USB port?
    Adam - Ответить
    what do you do with the 5 charge pins? glue them in?
    dew_haro_boy - Ответить
    where to buy such a power board
    gamer2142 - Ответить
    Where do you get the new micro USB port?
    Canadian Patriot - Ответить
Заключение
14 участников успешно повторили данное руководство.
Jonathan Wear
Участник с: 02/09/16
1 220 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 11-2, Cheng Spring 2016 Участник USF Tampa, Team 11-2, Cheng Spring 2016
USFT-CHENG-S16S11G2
4 членов
Автор 8 руководств
18 Комментариев
In my model MicroUSB is on separate board and both ports were covered by min. 20ml of hot-melt adhesive.
I spent hour on cables separation by sponge pieces - it is very important to use again hot glue to restore hermetic (!) speakers encloser, otherwise you get annoing sound of shaking cable.
101 - Ответить
Mine was like that too! %#*@ hot glue made it a pain to pull the usb out. sadly i need a new usb board... mine 2 pads were completely gone... not worth trying to even fix the contacts...
Sammy Morini -
Good clear guide, but as reported by other earlier, steps starting from 17 will be different in case I/O board with USB is a separate piece of board covered with glue. You need hot glue gun to reassemble the unit after replacing the USC socket. Guy in below link shows the struggle with the glue: https://www.youtube.com/watch?v=N6ahpRyK...
piotr.kaszyca -
Anywhere I can just buy the whole usb i/o board?
Charles Burgos - Ответить
Hi
Did you find it and where ?
Thank You
Marc BERGER -
Where can I get he micro usb board????
James A Karsner - Ответить
Hi,
Thank You
Marc BERGER -
Hello where can i find this micro usb board please ?
flavien - Ответить
Hi,
Did you find it and where?
Thank You
Marc BERGER -
I’m searching too where I can find micro usb board.
Gianluca Todisco - Ответить
Hi ,
Thank You
Marc BERGER -
In my case, the usb slot is totally “glud” from behind:(
Guba Pumukli - Ответить
Hello i have repaired my jbl wih usb ports from Aliexpress . Thanks !!!!
cosminbruhovici - Ответить
Bloody h*ll, that was murder. Not the guide, but the task. It took me from 10am through to 2.30pm. My Flip 2 was a different build, and JBL had hot-glued everything under the motherboard. What a PIA. I should’ve just dumped the thing, but I persisted and to my surprise the repair worked. The Cage on my variant had an extra screw under the LED board, so be aware folks. Difficulty? 8/10 in my books. Buy a new one & flog your old (working) parts to mugs on eBay like me who have egos too big for their boots. I’d give the guide about a 7 as so much of my build was different (including screw sizes and board configurations), so I could only partly use it. But thanks anyway.
Anthony Vambery - Ответить
I accidentally broke the power cable which is connected to motherboard and on off button.. please tell how to repair or where to find replacement of that flex cable
Random Lucky - Ответить
Need a store that do this for a living, I dont want to take any chance I might ruined
Enudio Zayas - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 20
За последние 30 дней: 83
За всё время: 53,398
