JBL Flip 3 Battery Replacement
Выберете то, что вам нужно
  1. JBL Flip 3 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Battery Replacement: шаг 2, изображение 1 из 1
    • Loosen the two screws on each side and then carefully remove the outer frame to expose the inner components of the speaker.
    • Depending on your model, you may need to remove more screws along the sides or the spine.
  3. JBL Flip 3 Battery Replacement: шаг 3, изображение 1 из 1
    • Remove the 7 8.9mm Phillips #00 screws fastening the two side passive drivers. Then remove the side passive drivers themselves. Be sure to set them somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove silicone button covers by peeling back the silicone covering. This will expose the circuit board. Disconnect the ribbon cable. Carefully pry out the circuit board and set aside. Use a heat gun to remove all adhesive so that the ribbon cable can freely slide out of the slot in a later step.
  5. JBL Flip 3 Battery Replacement: шаг 5, изображение 1 из 1
    • Carefully remove the 5 pin connector from motherboard using your hands
  6. JBL Flip 3 Battery Replacement: шаг 6, изображение 1 из 2 JBL Flip 3 Battery Replacement: шаг 6, изображение 2 из 2
    • Unscrew the 2 8.9mm Phillips #00 screws holding the plastic battery cover. Carefully set them in a different safe spot to ensure that they are both not lost and not confused with the screws from step 2.
    • Remove the clear plastic battery cover.
  7. JBL Flip 3 Battery Replacement: шаг 7, изображение 1 из 2 JBL Flip 3 Battery Replacement: шаг 7, изображение 2 из 2
    • Gently heat adhesive located at tip of powerchip to melt the plastic fastening the battery to the housing. Be careful not to melt the plastic housing during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
  8. JBL Flip 3 Battery Replacement: шаг 8, изображение 1 из 1
    • Remove the ribbon holding the battery. When the ribbon is gently pulled until fully removed from the inner housing, the battery will be unfastened and removable.
Заключение
46 участников успешно повторили данное руководство.
College Student
Участник с: 02/22/17
3 455 Репутация
Автор 4 руководств
Команда
USF Tampa, Team S1-G2, Leahy Spring 2017 Участник USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 членов
Автор 17 руководств
30 Комментариев
where can I get replacement battery for Flip 3?
Gaurav Gupta - Ответить
You can get a replacement battery for the JBL flip 3 on AliExpress
Ezriel Greenman -
It is couple diffrent version of JBL Flip 3 speaker .
Dalibor Miljevic - Ответить
Yes, apparently the Flip 3 Stealth Edition looks slightly different. The procedure however is about the same, except screws are not covered by silicone covering.
johnnyheesterbeek -
my battery also went to !&&*!! anyone manage to get a replacement?? couldn't find one!
Oscar Motta - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 23
За последние 7 дней: 152
За последние 30 дней: 834
За всё время: 97,668
