Выберете то, что вам нужно
Remove plastic outer housing using hands or a standard spudger.
Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
15 участников успешно повторили данное руководство.
7 Комментариев
where did you source the drivers from?
i need help getting the front speakers only where would i get them???
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
