JBL Flip 3 Power Circuit Board Replacement
Выберете то, что вам нужно
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: шаг 1, изображение 1 из 1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: шаг 2, изображение 1 из 1
    • Carefully remove outer housing to expose the inner components of the speaker.
  3. JBL Flip 3 Power Circuit Board Replacement: шаг 3, изображение 1 из 1
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: шаг 4, изображение 1 из 1
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
Заключение
14 участников успешно повторили данное руководство.
James Bianco
Участник с: 02/20/17
151 Репутация
1 руководство автора
Команда
USF Tampa, Team S1-G2, Leahy Spring 2017 Участник USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 членов
Автор 17 руководств
5 Комментариев
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - Ответить
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - Ответить
The title says replacement, and you show only the removal.
Stanimir Nikolov - Ответить
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - Ответить
Change the battery
odii Emmanuel -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 42
За последние 30 дней: 159
За всё время: 30,043
