JBL Flip 3 Side Passive Driver Replacement
Выберете то, что вам нужно
  1. JBL Flip 3 Side Passive Driver Replacement, Side Passive Driver: шаг 1, изображение 1 из 1
    • Remove the plastic outer housing using your hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Side Passive Driver Replacement: шаг 2, изображение 1 из 1
    • Use your hands to carefully remove the outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 Side Passive Driver Replacement: шаг 3, изображение 1 из 1
    • Go around the outer edge of the side passive driver with a screwdriver to remove the seven 8.9mm Phillips #00 screws from both sides of the device. Make sure to set the screws aside somewhere they won’t get lost.
  4. JBL Flip 3 Side Passive Driver Replacement: шаг 4, изображение 1 из 2 JBL Flip 3 Side Passive Driver Replacement: шаг 4, изображение 2 из 2
    • Remove the side passive driver.
Заключение
5 участников успешно повторили данное руководство.
College Student
Участник с: 02/22/17
3 455 Репутация
Автор 4 руководств
Команда
USF Tampa, Team S1-G2, Leahy Spring 2017 Участник USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 членов
Автор 17 руководств
2 Комментариев
What the fock?!?!? Ohhh, you basterds. I see what kind of game you're playing. I'm coming to get ya'. I'm gonna track you down, so help me God. I won't rest until I feel the warm, sticky blood of this author, and anybody that looks like him!! I will have my vengeance! I shall reign down upon him like a…(ding!) Ooohh! My toaster pastries!
Johnny Johnson - Ответить
Do you know what would be great? If we could source these diaphrams, or speakers, or whatever is being shown here to replace. They are nearly impossible to source!!
Muhip Tuna Meti - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 16
За последние 30 дней: 53
За всё время: 10,247
