Введение
If the device will not charge and you have either tried a different working outlet or a different charger or even replaced the battery in the JBL Flip 5 speaker, you may want to try replacing the charging port.
Выберете то, что вам нужно
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Once all the clips are released, you will be able to pull up that edge of the case.
Once all the clips are removed, you can gently remove the outer case.
The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
Use a Phillips screwdriver to remove the four 17mm-long screws securing the passive radiator bracket.
Once the screws are removed, use the metal spudger to remove the passive radiator bracket.
Set the radiator bracket aside.
Now you must remove the passive radiator.
Use the metal spudger to pry upwards to remove the plastic clips holding the passive radiator down.
Once the clips are removed, you can pull both of the passive radiators off
Focus on the side of the speaker where the charging port is located and inspect where the passive radiator was before it was removed.
Use your hands to unplug the charging cable that connects the charging port to the motherboard.
Unfasten the four 6 mm-long screws on the component that sits over the charging port.
Remove this piece with your hands.
There will be two tape like plastic pieces that hold the charging port's circuit in place.
Pull these pieces off and you will be able to pull the charging port and its circuit out.
