Введение
Taking out the speaker for a replacement
Выберете то, что вам нужно
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Once all the clips are released, you will be able to pull up that edge of the case.
Once all the clips are removed, you can gently remove the outer case.
The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
Once screws are fully out make sure to carefully pull out so the wires connected don't get damaged.
Once you carefully lift up the speaker, gently disconnect the wire that connects the speaker to the motherboard.
