Введение
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
Выберете то, что вам нужно
Turn the device upside down so that the three rubber pads are facing up.
Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
Remove the heated rubber pad with a plastic opening tool.
Repeat steps 2 and 3 for the two remaining rubber pads.
Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
Cut the black wire (leading to the speaker you are replacing) with a pair of wire cutters.
Cut the red wire (leading to the speaker you are replacing) with a pair of wire cutters.
just pull of the plug, no need to cut the wires
To reassemble your device, follow these directions in reverse order.
5 участников успешно повторили данное руководство.
8 Комментариев
Where can I buy the replacement speaker?
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
little bit late i just order it after 2 years searching
Do these work as original driver are 8 ohm?
Where can i buy these speakers (3w-8 omhns)?
My JBL "on Stage III" Ipod Sound Dock with remote - World Wide Voltage speakers r all damage, i want a new spaekars, how can i get his.
How to find these component speaker
My jbl stage 2 speaker is broke
I want to buy new ones but i did not find them
Let me know if u arrange
