JBL Pulse 3 Outside Casing Replacement
Выберете то, что вам нужно
  1. JBL Pulse 3 Outside Casing Replacement, Speaker Grill: шаг 1, изображение 1 из 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Outside Casing Replacement: шаг 2, изображение 1 из 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Outside Casing Replacement: шаг 3, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement: шаг 3, изображение 2 из 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Outside Casing Replacement, Outside Casing: шаг 5, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement, Outside Casing: шаг 5, изображение 2 из 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    #00 not required, successfully opened with PH#1
    Stephen Hoefler - Ответить
  5. JBL Pulse 3 Outside Casing Replacement: шаг 6, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement: шаг 6, изображение 2 из 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    Ca I Specifically buy the top ring
    Julian Cruz - Ответить
    I've the same concern as the comment above, can I buy the top ring separately?
    Yousef - Ответить
    Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
    Kusala Kumsinda - Ответить
    Is there any other place to get this part? It doesnt ship to the UK
    Amelia - Ответить
  6. JBL Pulse 3 Outside Casing Replacement: шаг 7, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement: шаг 7, изображение 2 из 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Outside Casing Replacement: шаг 8, изображение 1 из 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Outside Casing Replacement: шаг 9, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement: шаг 9, изображение 2 из 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
    Richard Devos - Ответить
  9. JBL Pulse 3 Outside Casing Replacement: шаг 10, изображение 1 из 2 JBL Pulse 3 Outside Casing Replacement: шаг 10, изображение 2 из 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Outside Casing Replacement: шаг 11, изображение 1 из 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
Заключение
4 участников успешно повторили данное руководство.
Kaitlyn Greenfield
Участник с: 09/20/18
1 161 Репутация
Автор 6 руководств
Команда
Central Washington University, Team S1-G2, Pengilly Fall 2018 Участник Central Washington University, Team S1-G2, Pengilly Fall 2018
CWU-PENGILLY-F18S1G2
3 членов
Автор 12 руководств
3 Комментариев
Wherr can I get or buy top ring for Pulse 3?
Mark Christian Mariñas - Ответить
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
Kaitlyn Greenfield - Ответить
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
Raffaele T. - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 31
За всё время: 3,015
