Введение
Often times when buttons have become unresponsive, a faulty button board may be the cause. In this guide we will show you how to access and replace the button board.
Выберете то, что вам нужно
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Pull black piece on top of socket away from board to loosen, then detach the cable.
5 участников успешно повторили данное руководство.
