Введение
This guide is for replacing the outer casing of the JBL Pulse for when some kind of damage has occurred to the outside of the device.
Выберете то, что вам нужно
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
2 участников успешно повторили данное руководство.
