Введение
This guide shows how to replace the speaker inside of the device. Replacing the speakers is only necessary if the device is playing distorted or no audio.
Выберете то, что вам нужно
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Remove two black 9mm PH0 screws from outside of inner casing on each side.
Use your metal spudger to unhook the bracket holding the case together.
Pull apart the casing with your hands.
Remove cables by pulling firmly.
Remove four black PH0 9mm screws.
The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
6 участников успешно повторили данное руководство.
8 Комментариев
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
