Введение
For this replacement guide, you will be replacing the buttons located on the left side of the headphones. There could be a few different reasons why the buttons might not be working correctly, and replacing them could solve the issue. This guide is relatively easy and should only require a jimmy tool.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the three screws that secure the motherboard.
Gently move the motherboard out of the way, with care not to strain the attached cables.
Use a jimmy to wiggle the button off the edge, then push the buttons inside of the headphone chassis.
Remove the buttons.
