Введение
If you’re JBL Xtreme 2's speaker sounds disoriented or is making no sound, use this guide to replace the speaker(s). The speakers inside are used to make the bass for the experience of listening to music. When a speaker is damaged you will hear distorted music or none at all.
Before beginning make sure to power off the speaker and disconnect from any external power source.
Выберете то, что вам нужно
Use a spudger or other prying tool to gently pry open the middle section of the speaker.
Once you have the speakers exposed like in the image, at the bottom part you will snap open the back end piece of the grill still attached.
Using a Phillips #00 screwdriver, remove the four 12.9 mm screws securing the faulty speaker.
Lift the speaker out of its housing and you will see two cables connecting the speaker. Pull the speaker towards you and each of the cable connectors away from you.
Do the same for both cables.
2 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
Happened to me too. Please include the images about the screw from the other repair manual (for the battery)
