Введение
If the battery in your JBL Xtreme 3 (JBLXTREME3BLKAM) portable Bluetooth speaker is failing or has completely died, this guide will instruct you on replacing the battery.
Please review information about proper battery disposal.
Warning: Please take precautions if you suspect a swollen battery.
Выберете то, что вам нужно
Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
Use your hands to finish removing the outer case of the device.
Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
Remove the speaker from the shell.
Turn the device so that the control buttons are facing down.
Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
Carefully remove the panel.
Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
5 участников успешно повторили данное руководство.
