JBL Xtreme Bass Radiator Replacement
Выберете то, что вам нужно
  1. JBL Xtreme Bass Radiator Replacement, Cover: шаг 1, изображение 1 из 1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Bass Radiator Replacement: шаг 2, изображение 1 из 2 JBL Xtreme Bass Radiator Replacement: шаг 2, изображение 2 из 2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Bass Radiator Replacement: шаг 3, изображение 1 из 2 JBL Xtreme Bass Radiator Replacement: шаг 3, изображение 2 из 2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Bass Radiator Replacement, Bass Radiator: шаг 4, изображение 1 из 3 JBL Xtreme Bass Radiator Replacement, Bass Radiator: шаг 4, изображение 2 из 3 JBL Xtreme Bass Radiator Replacement, Bass Radiator: шаг 4, изображение 3 из 3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Bass Radiator Replacement: шаг 5, изображение 1 из 3 JBL Xtreme Bass Radiator Replacement: шаг 5, изображение 2 из 3 JBL Xtreme Bass Radiator Replacement: шаг 5, изображение 3 из 3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
Заключение
12 участников успешно повторили данное руководство.
Benny Huynh
Участник с: 02/15/17
1 929 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-1, Sullivan Spring 2017 Участник USF Tampa, Team 1-1, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G1
4 членов
Автор 27 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 25
За последние 30 дней: 81
За всё время: 20,602
