Введение
This guide will show you how to remove the charging port of a JBL Xtreme. This guide requires soldering skills.
Выберете то, что вам нужно
Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
Locate and disconnect the the three plugs indicated in these pictures.
Locate the three Phillips head screws inside the zipper compartment and unscrew them.
Pull the zipper panel free from the device.
Under the zipper panel are eight more Phillips head screws. Unscrew them and carefully lift the battery cover.
The first image highlights the charging port.
Locate 6 metal pins highlighted in the second image and use a solder iron to disconnect the pins.
14 участников успешно повторили данное руководство.
Один комментарий
Please I have a JBL XTREME that sparks each time I plug it. What could be the cause
