Введение
This will show how to change the battery .
  1. 8.4 V battery pack for the JBL Extreme.
    • 8.4 V battery pack for the JBL Extreme.
  2. Unscrew the screws and decover the shell.
    • Unscrew the screws and decover the shell.
  3. Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue because of air tightness.
    • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue because of air tightness.
  4. Solder up the connectors + and - . Use a DC hollow bush 5.5 x 2.1 for the current supply. Isolate the ends of the cables. Solder up the connectors + and - . Use a DC hollow bush 5.5 x 2.1 for the current supply. Isolate the ends of the cables.
    • Solder up the connectors + and - . Use a DC hollow bush 5.5 x 2.1 for the current supply. Isolate the ends of the cables.
  5. Battery 8,4 Volt. 13200mAh 8,4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
    • Battery 8,4 Volt. 13200mAh 8,4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
  6. Solarstorm 2S2P 18650 Battery Case.
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
Заключение
Особая благодарность этим переводчикам:
100%
These translators are helping us fix the world! Хотите внести свой вклад?
Начните переводить ›
Bert
Участник с: 27.06.2017
181 Репутация
1 Guide authored
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - Ответить
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - Ответить
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - Ответить
Hi.
See the comment higher.
Martin Kubica
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 12
Past 7 Days: 93
Past 30 Days: 371
За всё время: 13,914
