Введение
Sometimes a video will not be able to record audio or it could be muffled or scrambled. If you are sure that the problem lies in the microphone you should replace it. To remove the microphone you will need a Phillips #000 screwdriver, small plastic opener, and metal spudger.
This guide requires removing a lot of screws so it is important to keep track of which screw goes where. All screw heads are Phillips size #000.
Выберете то, что вам нужно
Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
Remove the 3.1 mm screw.
Remove the three 5.3 mm screws from the back of the camera.
From the bottom of the camera remove the following four screws:
5.3 mm
3.1 mm
5.1 mm
3.5 mm
Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
Remove the 5.4 mm screw next to the snapshot button.
Инструмент, используемый на этом этапе:Tweezers$4.99
Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
Insert the cables from the new port panel into their inputs and flip the locks to the down position.
From the inside of the camera remove these six screws.
3.3 mm
3.6 mm
3.1 mm
4.3 mm
4.3 mm
3.7 mm
From the top of the camera remove the two 3.1 mm screws securing the lens to the camera frame.
From the bottom of the camera remove the 3.2 mm screw next to the battery release switch.
Remove the 9.1 mm screw next to the menu and volume control label.
Remove the lens cap housing.
Remove the two 3.1 mm screws from the inside of the camera.
Remove the plastic cover piece next to the silver light button.
Remove the 3.1 mm screw securing the lens to the circuit board.
Remove the two 3.3 mm screws from underneath the battery port.
Take the cassette holder and circuit board by lifting it out of the camera frame.
Remove the two 3.6 mm screws.
Remove the two 1.8 mm screws then the plate.
Remove the six cables (one is underneath the metal plate) connecting the cassette holder to the circuit board.
To unplug two of the cables you must first pull the lock tabs out (towards the cable) then remove the cable.
Remove the three screws securing the microphone housing and camera operation buttons to the frame with the following sizes:
4.3 mm
3.1 mm
4.2 mm
Remove the 4.3 mm screw on the bottom of the camera frame.
Remove the two 4.3 mm screws above the LED securing the microphone housing to the frame.
Open the cassette holder to reveal a 2.4 mm screw on the bottom of the camera and remove it.
Make sure the camera operation buttons are positioned completely outside of the camera frame.
Gently lift the microphone housing from the front-bottom side of the camera and remove it from the frame.
Remove the two 1.6 mm screws securing the microphone casing.
Pull off the microphone casing.
Еще один человек закончил это руководство.
