Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The first step in the service of this device begins with the removal of the front panel assembly. This will allow access to other serviceable components within the device.
  1. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver. Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver. Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers. Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  5. Gently remove the front panel from the steel enclosure.
    • Gently remove the front panel from the steel enclosure.
  6. Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger. Be careful not to scratch or damage components or features of the circuit board with the metal spudger Be careful not to scratch or damage components or features of the circuit board with the metal spudger
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
Заключение
Marshall Andersen
Участник с: 02.10.2018
665 Репутация
Автор 6 руководств
Команда
Linn Benton Community College, Team S1-G6, Johnson Fall 2018 Участник Linn Benton Community College, Team S1-G6, Johnson Fall 2018
LBCC-JOHNSON-F18S1G6
3 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 197
