Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removal of the passenger side panel of the device will allow access to other internal components.
Выберете то, что вам нужно
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
Remove the top panel.
Remove the five pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
