Введение
This guide illustrates the disassembly of the entire front panel assembly. This allows access to serviceable components, including the touch screen display. Replacement parts are available here.
Выберете то, что вам нужно
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
Remove the four pan-head 0-80 x 1/8" stainless steel machine screws using the Phillips #00 screwdriver.
Remove 2 pan-head 0-80 x 1/8" black finish machines screws using Phillips #00 screwdriver.
Remove 2 pan head zinc plated 1/64 x 3/16" machine screws using Phillips #0 screwdriver.
Remove the metal retaining shroud.
Remove the fabric disk drive passage liner.
Remove the white plastic button retainer.
Remove LCD display.
Remove touch-activated side button display.
Remove global touch screen assembly.
2 участников успешно повторили данное руководство.
3 Комментариев
To whom it may concern,
I successfully replaced the touch screen to my JVC, KW-V820Bt but ran into a small snag.
My screen is back to life but it does not respond to any touch.
Does it need to be calibrated ?
Thank You,
Much Appreciated for any help.
Arturo R.
pantepec00@gmail.com
Hi Arturo, without looking at the device, I can only guess. But, if it doesn’t respond to any touch whatsoever, you might take a second look at the touchscreen component itself (that is the clear glass sheet, step 9, picture 3) and be sure you have that thing connected properly and there is no damage to that little ribbon cable itself. I’m not aware of any calibration procedure, but I could be wrong.
Hi
I have a bootloop issue with JVC KW-V820BT
How do I go about finding what is causing it ?
Thanks
