Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Jalousie windows are a mainstay in older mobile homes. Replacing windows is expensive, so I'm replacing my non-functional gearboxes with new units. In most cases, replacing the gearbox will enable the window to crank fully open and closed again. It's simple in theory, the hardest part is maneuvering in the limited space to replace one, but I'll show you how to get it done!
Выберете то, что вам нужно
Using a Phillips screwdriver, remove the two screws from the mount at the opposite end of the bar.
Lift the bar up slightly so that it pivots and the gearbox will roll about 30 degrees back.
Angle the bar as you're bringing it forward so that the gearbox clears the frame first, then the mount side can be brought forward too.
Place the new gearbox onto the end of the bar. Be sure to line up the slots in the bar with the two ridges inside the sleeve of the gearbox.
With the new gearbox in place, angle the bar back into place with the mount end going in first. .
Keep the bar slightly rotated so that the gearbox will clear the window frame.
Swing the gearbox and the mount into their original positions, matching the screw holes is a good reference.
Reinstall the screws in the gearbox and mount.
Mission accomplished!
6 участников успешно повторили данное руководство.
13 Комментариев
thank you , so simple and effective
thank you so much for taking the time to share your knowledge and experience in this DIY project. I have several windows like this I need to fix.
Where do you buy the gear boxes from?
Ace hardware they have all kinds
