Jawbone Big Jambox Battery Replacement
Выберете то, что вам нужно
  1. Jawbone Big Jambox Battery Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
    • Due to interior clips holding the end caps in place, use caution when applying force.
  2. Jawbone Big Jambox Battery Replacement: шаг 2, изображение 1 из 3 Jawbone Big Jambox Battery Replacement: шаг 2, изображение 2 из 3 Jawbone Big Jambox Battery Replacement: шаг 2, изображение 3 из 3
    • Turn the Jambox upside down. Peel the indicated rubber tabs off, using a plastic opening tool if necessary.
    • You may want to only take the tabs half way off to avoid re-gluing when reassembling.
    • Remove the three T6, 7.0 mm screws under each rubber tab.
    • Because the screws are a different length, set the screws aside.
  3. Jawbone Big Jambox Battery Replacement: шаг 3, изображение 1 из 3 Jawbone Big Jambox Battery Replacement: шаг 3, изображение 2 из 3 Jawbone Big Jambox Battery Replacement: шаг 3, изображение 3 из 3
    • With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
    • Unscrew indicated T6 9.7 mm screws.
    • Gently loosen the tabs from their anchor points so the bottom may be removed.
    • Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
  4. Jawbone Big Jambox Battery Replacement: шаг 4, изображение 1 из 1
    • Pry up the bottom panel by lifting from the device.
    • Pull the bottom up. This may take a bit of force as the bottom is glued to device.
    • Once removed, the battery will now be visible.
  5. Jawbone Big Jambox Battery Replacement: шаг 5, изображение 1 из 2 Jawbone Big Jambox Battery Replacement: шаг 5, изображение 2 из 2
    • Before unscrewing, take a picture of the top view. That way, when you're reassembling the device, you'll know the orientation of the metal grounding plates.
    • Unscrew the eight indicated T6 9.8 mm screws. Remove metal grounding plates.
  6. Jawbone Big Jambox Battery Replacement: шаг 6, изображение 1 из 1
    • Once all eight screws are removed, pry the sides of the Jambox to lift the body from it's shell.
  7. Jawbone Big Jambox Battery Replacement: шаг 7, изображение 1 из 1
    • With the battery facing forward, remove the three indicated T6 9.5 mm screws.
    • Once the screws are removed, lift up the small plastic plate, revealing the auxiliary board underneath.
  8. Jawbone Big Jambox Battery Replacement, Battery: шаг 8, изображение 1 из 2 Jawbone Big Jambox Battery Replacement, Battery: шаг 8, изображение 2 из 2
    • Remove the indicated T6, 7.4mm screw holding the auxiliary board in place.
    • Carefully lift the circuit board up and off to the side.
  9. Jawbone Big Jambox Battery Replacement: шаг 9, изображение 1 из 1
    • Pull on the red and black cables under the auxiliary board to disconnect the battery.
  10. Jawbone Big Jambox Battery Replacement: шаг 10, изображение 1 из 2 Jawbone Big Jambox Battery Replacement: шаг 10, изображение 2 из 2
    • The battery is connected to the Jambox with double-sided sticky tape. Use your finger to pry out the battery.
    • Place a new battery in the old battery’s place. Reverse these steps to connect the new battery.
    • When plugging in the new battery, ensure the red and black wires are separated around pegs so that they are not pinched when the auxiliary board is replaced.
Заключение
67 человек успешно провели ремонт по этому руководству.
Abby Cybula
Участник с: 04/01/15
1 986 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 24-5, Lancaster Spring 2015 Участник Cal Poly, Team 24-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G5
4 членов
Автор 11 руководств
33 Комментарии к руководству
Where do I buy the battery.
Kevin Foti - Ответить
http://www.ebay.com/itm/322588700358?ul_... :Here is someone who made and sell the battery for Jambox and Big Jambox, i hope this could be helpful
Lin -
да где аккумулятор купить то?
speedlexx - Ответить
на рынке покупаются стандартные 18650 и меняются на старые акку из колонки. что б пошла зарядка нужно дать больше ток.
цена вопроса ~ 1200₽ с работой
Max -
Where do I go to purchase a battery?
Edward Brown - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 31
За последние 7 дней: 238
За последние 30 дней: 566
За всё время: 72,075
