Введение
While this guide is essential to replacing many parts on the Jawbone MINI JAMBOX, it requires an advanced level of technical knowledge. Only attempt to remove the motherboard if it is absolutely necessary.
Выберете то, что вам нужно
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
Carefully remove the end panel.
Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
Push against the side without end cap to slide the internal components out of the case.
While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
Remove all connecting ribbons from the motherboard.
One ZIF or "zero insertion force" ribbon connecting at the side.
One standard ribbon connector in the middle (Note: this ZIF ribbon is lightly glued to the surface).
Desolder the grounding plug from the motherboard.
Make sure your soldering iron is tinned and carefully touch the tip of your iron to the grounding lug. Allow the the solder to liquify. While liquified, lift the motherboard off the grounding lug.
6 участников успешно повторили данное руководство.
