Введение
The Jawbone MINI JAMBOX has an aluminum unibody outer shell. You must remove this outer shell in order to replace the inner components.
Выберете то, что вам нужно
Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
Carefully remove the end panel.
Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
I didn’t have a T6 bit. My set only went down to T7. I was able to seat a jeweler’s flat-blade screwdriver into the head, press down firmly, and turn the screw head. Even after breaking the screw loose, there was significant drag to turn it, so be careful of the tool slipping out of the screw head.
Push against the side without end cap to slide the internal components out of the case.
While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
Еще один человек закончил это руководство.
Один комментарий
Does anyone know where to find replacement outer shells for the big jambox?
I was able to remove the cover without cosmetic damage. I used a 6” sharp knife blade, slid it into the crack and twisted. As Kevin states in Step 2, you are trying to lift up the center of the long edge. The top short end has two tabs and the bottom end has one big tab in the center.
Student4Life - Ответить
Yes I agree with Student4Life. Just insert the spudger into the top short edge (the edge without rubber foot) and you can remove the cover without noteble damage.
Leon - Ответить
