Jazz Digi-Stix JDC11 Case Replacement
Выберете то, что вам нужно
  1. Jazz Digi-Stix JDC11 Case Replacement, Battery: шаг 1, изображение 1 из 2 Jazz Digi-Stix JDC11 Case Replacement, Battery: шаг 1, изображение 2 из 2
    • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
  2. Jazz Digi-Stix JDC11 Case Replacement: шаг 2, изображение 1 из 1
    • Tilt device so that batteries slide out.
  3. Jazz Digi-Stix JDC11 Case Replacement, Capture Button: шаг 3, изображение 1 из 3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: шаг 3, изображение 2 из 3 Jazz Digi-Stix JDC11 Case Replacement, Capture Button: шаг 3, изображение 3 из 3
    • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
    • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
  4. Jazz Digi-Stix JDC11 Case Replacement: шаг 4, изображение 1 из 3 Jazz Digi-Stix JDC11 Case Replacement: шаг 4, изображение 2 из 3 Jazz Digi-Stix JDC11 Case Replacement: шаг 4, изображение 3 из 3
    • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
    • Gently seperate the two halves of the device.
    • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
    • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
  5. Jazz Digi-Stix JDC11 Case Replacement: шаг 5, изображение 1 из 1
    • Carefully separate the grey side bar from the case and set it aside.
  6. Jazz Digi-Stix JDC11 Case Replacement: шаг 6, изображение 1 из 1
    • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
  7. Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: шаг 7, изображение 1 из 3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: шаг 7, изображение 2 из 3 Jazz Digi-Stix JDC11 Case Replacement, Board/Microphone/Battery Compartment: шаг 7, изображение 3 из 3
    • To remove the microphone from the case, insert the tip of the spudger under the microphone's edge and pry it away from the case.
  8. Jazz Digi-Stix JDC11 Case Replacement: шаг 8, изображение 1 из 3 Jazz Digi-Stix JDC11 Case Replacement: шаг 8, изображение 2 из 3 Jazz Digi-Stix JDC11 Case Replacement: шаг 8, изображение 3 из 3
    • Unscrew the three 5.6 mm Phillips #00 screws that connect the battery compartment to the case.
    • Remove the battery compartment from the case of the device.
  9. Jazz Digi-Stix JDC11 Case Replacement, Case: шаг 9, изображение 1 из 2 Jazz Digi-Stix JDC11 Case Replacement, Case: шаг 9, изображение 2 из 2
    • Remove viewer from the top-left corner of the case by gently pulling it away.
  10. Jazz Digi-Stix JDC11 Case Replacement: шаг 10, изображение 1 из 1
    • If the replacement case does not have a wrist strap, remove your device's wrist strap by feeding the plastic tab through the loop cord, and then pulling it all the way through.
Заключение
Katelyn Fry
Участник с: 03/11/13
1 Репутация
Автор 7 руководств
Команда
Clemson, Team 12-3, Benson Spring 2013 Участник Clemson, Team 12-3, Benson Spring 2013
CLEM-BENSON-S13S12G3
3 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 202
