Введение
This guide will guide the user to effectively remove and replace the battery. This replacement will take 20-30 minutes. However, if the guide is followed to the letter, the task will be accomplished with minimal damage to the device.
Выберете то, что вам нужно
Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
