Введение
This guide will guide the user to effectively remove and replace the speaker. This replacement will take around 15-20 minutes. However, if the guide is followed to the letter, the task will be accomplished with minimal damage to the device.
Выберете то, что вам нужно
Start by removing the back panel.
Remove the 4 screws holding the device together: two on the left side, and two on the right side.
Using a metal spudger, carefully pry open the case.
Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
Remove Speaker wires when the solder liquifies.
Еще один человек закончил это руководство.
