Введение
Soldering skills are required to replace the battery in this device. Check out iFixit's Soldering Skills guide for more help.
Выберете то, что вам нужно
Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
Remove the yellow tape from the sides of the battery, and the surrounding components.
Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
Using a plastic opening tool or spudger, slowly pry the battery away from the board.
Use a two sided adhesive to secure the new battery in place.
Solder or crimp the wires back together to reattach to the motherboard.
Replace any yellow tape that you removed at the beginning to secure the wires back in place.
1 Комментарий к руководству
Very good instructions.....but where do I buy the repkacement battery from?
