Введение
Missing a stone on your favorite jhumki can be frustrating, especially when it holds sentimental or cultural value. This guide is simple and straight forward to help you restore the gem on your jhumki without spending a fortune or having to throw away your piece.
With a few tools, you will be able to restore your jhumki and add a few more wears to its life span!
Выберете то, что вам нужно
Identify the missing piece.
Identify the size of the gem, consider the color, and gauge the depth of the hole.
Use an alcohol prep pad to strip the surface of any oils.
Repeat this process with the gem.
Using your super glue, cover the site of the missing gem completely.
Allow for the glue to settle into the cracks before applying the gem.
Use your tweezers to gently grab the gem and place it on the glue.
Use the tweezers to adjust the gem as needed.
After allowing 30 minutes for the gem to dry, use an alcohol pad to remove any excess glue from the jhumki.
